peter anson wrote:Yes, sad but true. If you are making your own fitting, use 0.058" WT tube for a much better fit, or better still, use 0.065" WT tube, but you will need to run a 5/8" drill or reamer through the tube for the tail spring to fit.
racaldwell wrote:I used 0.004" SS shim material as a wrap around the rod. Worked great, no slop now. I punched a hole in the shim so the bolt keeps it in place. The end of the shim is flush with the end of the tube.
I think I wrote about it on the Xenos page.
Rick Caldwell
Xenos 0057 forward fuselage parts
