How to make bends: ONX-F09-03?
Discussion for Onex builders on specific plans page experience. These posts are limited to technical suggestions such as assembly order, challenges, or techniques related to specific plans pages.
Postby dhogue » Thu Nov 09, 2017 6:59 pm
Hello Sonex/Onex builders,
I am posting to ask:
What are ways to make the required bends in the Seat Sling (seat) on Onex plans page ONX-09 detail 03...that does not require a bending brake?
Don
Don Hogue
Onex 0173: Tailwheel: AeroVee Turbo.
Horiz/Vert Stabs, Rudder/Elevators, Fwd/IB/OB/Aileron Bellcranks on Ribs and Main Fwd/Aft Center Wing Spars, Fuselage : Complete.
WIP: Wings
dhogue
Re: How to make bends: ONX-F09-03?
Postby wlarson861 » Fri Nov 10, 2017 12:54 am
For the Sonex I used the edge of my bench at the bend point and clamped it down with a heavy board, then used a straight board to start the bend down.
Bill Larson
N861SX
wlarson861
Postby Direct C51 » Fri Nov 10, 2017 1:47 am
That's how I did it. Laid the bend line at the edge of my best work table, clamped angle iron or something similar on top, and used a 2x4 and my body weight.
Direct C51
Postby x3 skier » Fri Nov 10, 2017 9:31 am
The board/bench edge approach is how I made other bends in big pieces like the fuselage sides, but for the seat, I used a brake at a friend’s shop. HF has some cheap brakes.
Cheers
Onex 202, Finishing Fuselage Kit, Controls/Gear/Engine Config kit delivered.
x3 skier
Postby dhogue » Sat Nov 11, 2017 8:46 am
Thanks for the solution gents.
Don Hogue
WIP: Wings
dhogue
Return to Onex Plans
