Tail spring slop
Tail spring slop
Postby Rofomoto » Wed Jun 06, 2018 5:04 pm
I’m plans building and the tail spring weldment calls out for .750 dim 4130 tubing with a wall thickness of .049 so that is what I used. The ti spring rod is .625 dim. So .027 of slop. Is this correct? Thanx billy
1735
Longassproject
Rofomoto
Re: Tail spring slop
Postby Bryan Cotton » Wed Jun 06, 2018 5:48 pm
Mine was sloppy. I bonded it in while the fuselage was upside down. That means the epoxy holds the spring so any impact is metal to metal.
Postby peter anson » Wed Jun 06, 2018 7:35 pm
Yes, sad but true. If you are making your own fitting, use 0.058" WT tube for a much better fit, or better still, use 0.065" WT tube, but you will need to run a 5/8" drill or reamer through the tube for the tail spring to fit.
Postby Rofomoto » Wed Jun 06, 2018 8:03 pm
peter anson wrote:Yes, sad but true. If you are making your own fitting, use 0.058" WT tube for a much better fit, or better still, use 0.065" WT tube, but you will need to run a 5/8" drill or reamer through the tube for the tail spring to fit.
Darn it. Already done and on. So do I buy New over size ti or can I use shim material?
1735
Longassproject
Rofomoto
Postby tonyr » Wed Jun 06, 2018 9:02 pm
I used some stainless shim material, .010 wrapped around the rod..
A slight bit of movement left in it... epoxying the lot in would fix it but couldn't be bothered
Cheers
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby Area 51% » Thu Jun 07, 2018 7:46 am
I had a 1/4-28 nut welded to the bottom aft of the tube and used a set screw to remove the slop. Put a small piece of nylon between the titanium and set screw to avoid fretting too.
Postby DCASonex » Thu Jun 07, 2018 8:21 am
The part purchased from Sonex also had a LOT of slop, even with their thick powder coat. Powder coat was not even so ran in tool to level it out, then wrapped spring in multiple turns of 0.004" SS shim stock. If was making these from scratch, would go ahead and remake with the heavier wall tubing or will be kicking yourself every time you look at it.
Postby Rofomoto » Thu Jun 07, 2018 8:42 am
Thanx for all the help...should have used .058.
1735
Longassproject
Rofomoto
Postby racaldwell » Wed Jun 13, 2018 12:56 pm
I used 0.004" SS shim material as a wrap around the rod. Worked great, no slop now. I punched a hole in the shim so the bolt keeps it in place. The end of the shim is flush with the end of the tube.
I think I wrote about it on the Xenos page.
Rick Caldwell
Xenos 0057 forward fuselage parts
racaldwell
Postby Rofomoto » Wed Jun 13, 2018 12:59 pm
racaldwell wrote:I used 0.004" SS shim material as a wrap around the rod. Worked great, no slop now. I punched a hole in the shim so the bolt keeps it in place. The end of the shim is flush with the end of the tube.
Rick Caldwell
Thanx Rïck. That’s what I’m doing
1735
Longassproject
Rofomoto
Return to Sonex Plans
