inboard main spar
inboard main spar
Postby bipbuilder » Wed Oct 12, 2016 8:35 pm
First time onex builder here. Have completed outboard spars and am currently working on the inboard spar assembly. Having difficulty interpreting the drawing and was wondering if anyone could clarify them. Especially having difficulty with the spacer plates on the end and the pivot plates. Additional drawings or photos would be helpful.
bipbuilder
Re: inboard main spar
Postby Mike53 » Wed Oct 12, 2016 8:46 pm
http://www.onexmike.org/spar--inboard.html
Hope this clears it up a little.
Mike
Mike
Antoine de Saint-Exupery
Mike53
Postby bipbuilder » Sat Oct 15, 2016 8:55 am
Thanks for the info. About an hour after posting I had an"aha" moment . But the pictures confirmed my revelation. Also when Torque in the an bolts on the spar to 25 inch pounds it didn't seem very tight. Was wondering if that is the right spec.
bipbuilder
Postby lstinthot » Sat Oct 15, 2016 10:53 am
I thought the same thing about how little the torque value is. Referring to the AC43-13, it also states to not over torque and gives a value of 23 inch pounds for a 10-32 screw and 20 for an 8-32 screw. I watched a video that also mentioned to not get the desire to overtorque. One thing I did read in AC43 was to take into account the running torque so the final torque felt on the shaft would be 23 or 25 inch pounds. I take this to mean if it takes 3 inch pounds to turn the nut, the torque wrench needs to be set at 28 inch pounds to get a torque of 25. Have not found out for sure if that is what it means yet. I have not done final torque of my fasteners yet.
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Postby n982sx » Sun Oct 16, 2016 8:33 pm
Yes, run on torque is the torque it takes to spin the nut. With nylon insert nuts for AN-3 bolts, I consistently measured them at 7 inch pounds.
So, if you torque them to only 25 inch pounds, that is not enough.
Bob Meyers
Built and Flying Sonex N982SX http://n982sx.com
Built and Flying RV-14 N626KM http://n626km.com
n982sx
Return to Onex
Users browsing this forum: No registered users and 27 guests
