On a quest for the elusive "Dry AeroVee"
Re: On a quest for the elusive "Dry AeroVee"
Postby pappas » Sun Jun 04, 2023 11:39 am
As Peter noted, if Garret states the recommended max psi on our turbo is 45 psi or bearing failure may occur, all of these bearings should fail. We see O/P up to 100 psi on a cold weather start-up for a few minutes and 60-70 psi on warm day start-ups. Even at cruise, Sonex wants 40-50 psi. Maybe Sonex should weigh in on it?
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby Hap Hazard » Fri Mar 01, 2024 5:54 am
Bryan Cotton wrote:
bvolcko38 wrote:Why did you remove your oil filter?
Bill,
I'm not ready to dive into drilling and tapping the case for full flow. I am planning a couple of XC trips in a couple of months where I won't have the luxury of preheat overnight. I don't want the potential liability a few hundred miles from home of the oil filter popping on startup. Per Sonex the filter is only required if you have the turbo. So I'm taking it off for now. I think we can add pressure relief to our original pump and cover, which is what I'd like to do. That's a project for another day.
Hi Bryan,
Post-war, Micro-filtered oil systems was one of the biggest steps forward in modern engine longevity that we take for granted today and gives marked improvement in engine reliability. It’s an issue that Revmaster fully appreciate and obviously catered for in their engines. Changing the oil every 25 hour helps, but it doesn’t stop foreign particles being transported around the system and doing main-bearing damage. (Remember, your crank is like your spine in your body, look after it!).
FYI I am looking to fit a certain product (they are terrified of litigation in aircraft use, so I won’t name them) for the oil pump with the spin-on oil filter. Hopefully this will fit/work with the current Sonex exhaust system/cowl, baffles, etc, but I will know soon enough as I am putting the engine back together now with the cases bolted to my engine stand as I type.
What I did was to bored out the castings oil ways slightly larger (but have left the hole size standard where it bolts up to pump itself), flowed the 90 deg bends where the oil changes direction out of the pump and into to casting galleries and taken 45 g (1.6 Oz) out of the casting weight by taking as much excess aluminium off as I dare, to reduce weight a bit more (to put that into context, about the equivalent weight of around 6x 5/16th bolts 1-1/4 long!
Will let you know how it goes, but personally I wouldn’t be too quick to get rid of a micro-filtration system. On leaving the subject, although the aircraft came with the brand-new Sonex supplied mini-sump kit (not fitted) with paper filter, I do not trust a “suction” filtered system at all with any of my engines, hence why I don’t intend bolting it on to my motor….
Again, I refer readers back to what Revmaster does as a standard feature of their engine…..
HH
Hap Hazard
Postby BRS » Fri Mar 01, 2024 11:13 am
I'm a fan of the Revmaster oil-filter/oil-pump setup. Looks to me that it would bolt onto a Aerovee, is that not the case? I don't know if they would sell just their oil filter/pump assy.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby Area 51% » Fri Mar 01, 2024 11:32 am
I had the spin-on oil filter/pump assembly on my Aerovee. You do need to fit a short filter to clear the exhaust and a relief needs to be cut into the cowl. but other than that, there were no other fitment issues.
The mini-sump I installed had a washable filter and a relief valve if the oil was too thick to make it through the screen. I added it for the extra oil capacity and not necessarily for it's filtering ability.
I will definitely be installing the same on the upcoming engine. .
Postby Bryan Cotton » Fri Mar 01, 2024 3:11 pm
Hap Hazard wrote:Changing the oil every 25 hour helps, but it doesn’t stop foreign particles being transported around the system and doing main-bearing damage.
HH
HH,
All good points, thanks. I do realize the tradeoff is more frequent overhauls and I am flying enough that this will become reality. But the other tradeoff is I saved about 2.5 lbs, which is huge for me. Also I have had a couple of cold start oil filter blowouts. With the oil filter gone, this issue is also gone.
Postby funflyingguy » Tue Sep 24, 2024 9:06 am
Bryan Cotton wrote:Some followup on my air-oil separator. I had been really happy with it, but lately had been getting more and more oil on the belly. After my big trip to Tennessee, it was a real mess and the oil consumption seemed higher than 16 oz/10 hours. I removed the separator and opened it up. It looked really good inside. When I went to blow through the 1/4" fuel line I use as a drain line, it was somewhat obstructed. I cleaned that out. From here on out I will clean the drain line at every oil change. It's really easy to do.
Bryan Cotton wrote:Got my rockers back on, valves adjusted, and here is my drain:
bryan,
noticed in your picture you've routed your oil separator return line to your valve cover. i'm planning to add an oil separator to my aerovee also. what kind of separator did you use? this looks too small to be the unit offered by sonex. also, did you consider running the return line to a location on the block? i was wondering if there was an unused plug, etc i might do that. would you do anything differently with your pictured oil capture/return setup?
jim
3rd owner of sonex #1010 - N485PB
2017 can-am spyder F3T
2013 suzuki vstrom 650
2022 forest river popup camper
concord township, ohio
over 36 years flying
funflyingguy
Postby Bryan Cotton » Tue Sep 24, 2024 11:34 am
funflyingguy wrote:bryan,
jim
Jim,
I bought this one and modified it:
https://www.amazon.com/gp/product/B089VX5JB5
Back on page 11 of this thread are the mods I did to it. I think some of the earlier mods were on page 10.
Not too long ago I took out the steel scrubber pads. I was getting too much back pressure and I think they were getting clogged from old oil.
I am considering replacing the drain line with something larger. I have to clean it out each oil change because if I don't it gets clogged. I may make a section of it a hard line also.
Running to the valve cover seemed easiest to me. I didn't consider any other possibility.
Postby funflyingguy » Sun Sep 29, 2024 8:53 am
appreciate the update. i'll incorporate some of your upgrades into my install..
.... jim
funflyingguy
Postby karmarepair » Tue Oct 08, 2024 7:44 pm
I had a persistent leak from the sump plate nuts. After dropping the plate, replacing the screen, installing "lifetime" silicone gaskets with a light smear of permatex #2, and installing the acorn nuts on the sump plate studs with NEW copper washers (new copper crush washer on the VDO drain plug sensor too) with a generous smear of Permatex #2, and carefully tightened them up using a star pattern and little nibbles of torque (they were barely finger tight when removed): no more drips.
I've got SS pot scrubbers IN THE CASE, with a home made baffle plate between the case and the AeroVee breather outlet. The plane hasn't flown yet, so we'll see if we oil our belly.
Some details https://eaabuilderslog.org/?blprojentry ... tcat=&sid= Oil change hell.
https://eaabuilderslog.org/?blprojentry ... tcat=&sid= My breather setup.
I have a little bit of seepage from one of my clip-on valve covers. I may try going BACK to the silicone gasket on that side; after I posted the following I went to cork as the first engine run after initially installing the silicone gaskets was a festival of leakage. https://eaabuilderslog.org/?blprojentry ... tcat=&sid=
My push rod tubes are all dry. Dry around the prop hub. Case split is dry.
karmarepair
Postby Bryan Cotton » Tue Oct 08, 2024 9:51 pm
karmarepair wrote:I had a persistent leak from the sump plate nuts. After dropping the plate, replacing the screen, installing "lifetime" silicone gaskets with a light smear of permatex #2, and installing the acorn nuts on the sump plate studs with NEW copper washers (new copper crush washer on the VDO drain plug sensor too) with a generous smear of Permatex #2, and carefully tightened them up using a star pattern and little nibbles of torque (they were barely finger tight when removed): no more drips.
Mine always loosened up a bit. I drilled for safety wire.
Does anybody have a good source or part number for the seals that go under the two valve cover hold down bolts? I bought a bunch of EMPI o-rings and have gone through them already. They get chewed up and seem to be a single use item. My original seals from the Sonex AeroVee kit were more triangular shaped I thought. I did buy Sonex replacements but they were the same EMPI parts that I got from jbugs.
