by 13brv3 » Thu Mar 24, 2022 7:26 pm
Greetings,
While Dynon has my D180, I'm installing the hydraulic brakes, and would like to get the wheel pants installed. The previous owner of the project had the wheel pants on at some point, but with the tiny stock tires. I went with larger tires for the added prop clearance, and I don't see any way to squeeze those inside the stock wheel pants. It seems like one piece wheel pants aren't the best solution as tires get larger either, since you have to have an opening on the bottom that's large enough to fit over the tire. It becomes sort of a tire umbrella :-)
I did some general searching, and it seems there are people who squeezed the larger tires in the stock wheel pants, but I'm thinking they were not Onex builders. The extra 5/8" thickness of the Onex flat gear legs is a significant difference, so I'm pretty much ignoring those threads.
There were some comments about cutting the pants down the middle, and making them wider, which I think would have to happen. I hate fiberglass work, but it does look like that might work. The problem there that you also need some extra height to get the most out of the wheel pants. At this point, I'll take easy and cheap if I can make the stock wheel pants work.
In the long run, I'm thinking Van's pressure recovery wheel pants would be a better option. They're crazy expensive of course. Has anyone used those, or maybe other wheel pants for the larger tires?
Thanks
Rusty
Rusty
Fixed wing, gyroplane, A&P
