tx_swordguy wrote:If you search this site and ask specifics you can find out a lot of replacement parts, such as distributer caps and voltage regulators etc. Actual jabiru parts like valves and internals are a Jabiru only thing in most cases. I will tell you this about the voltage regulator. If you look for the Kubota part, ONLY get genuine kubota. You can type in the correct part number and 100 regulators will come up and look like the correct part but will be Chinese or Vietnamize and about $20. Don't buy the cheap import because it will let you down most likely in short order. I believe Jeff Shultz has a high dollar regulator that is supposed to be the bomb but it is about $200 last I heard.
Users browsing this forum: No registered users and 22 guests
