phenry wrote:Wes,
The mounts you found are just the sort of thing that could be employed. It is up to you what approach you take; I have seen several solutions that work fine.
Each solution has its own set of issues, the GPAS manifolds have bosses already moulded into them in about the right place, however they may not be big enough for the injector carriers you have identified and may need the bosses building up to take the threaded mount.
Some things to be considered:
• Holding the injector in place.
• Holding the fuel rail in place on the injector.
• Injector size. (see below).
• Injector wiring/plug clearance
• Fuel line connection to fuel rail.
When putting my system together choosing the correct injector was very tedious because we needed to select an injector that firstly delivered the right amount of fuel in its optimum operational range. We found the CHD 610 which is rated at 25 lb/hr best after trying a range of different sizes. This meant I had to make different fuel rails for each injector tested.
Keep in mind the penetration of the injector nozzle is a major consideration when choosing or building the mount.
There is no need for a position sensor because the whole system works from inlet manifold pressure, throttle open, more air and ECU adds more fuel and visa versa. Switching form EFI to normal operation in flight is no worse than a Sonex burp.
One factor to be considered in my system was that I use Semi-sequential injection because the Aerovee does not have a distributor, there is no way of knowing which of the cylinders in each bank is going to fire next. Not a problem you have to deal with so you could go Full Sequential.
phenry wrote:This is how I have done it and anything you take away from this is at your own risk.
phenry wrote:Note how the MAP sensor is mounted on the Pump/Pressure Regulator assembly. This made it easy to connect the regulator manifold pressure compensation line and MAP sensor in one place.
phenry wrote:A number of items are monitored in the usual manner CHT's etc.
phenry wrote:In addition we use a pot wired to the disused (Micro squirt) water temperature input to manually tweak the mixture (not used much once the tune is sorted).
phenry wrote:You could add an oxygen (O2) sensor but they hate Avgas, are expensive, need an exhaust modification and don't last long. Once you have it tuned it is set and forget.
The pump I am using draws 2.5 amps and can deliver up to 45 Lt/Hr.
