sonex892. wrote:Gday Phil. I replaced Velocity singles with an extreme. I too had some concerns about the small screen and intended to use the extreme only for flight and use a separate home made LCD instrument for the engine. I got used to using the extreme for both flight and engine display so discarded the separate engine display idea.
I normally use the same screen as Mike. Flight stuff to the left and engine to the right. The fact all parameters can be recorded on an SD card is a bonus. It also has an inbuilt GPS and will drive MGL autopilot servos.
Steve
Sonex 892
Users browsing this forum: No registered users and 40 guests
