Prop bolts install
Rotax 912 series discussion.
Re: Prop bolts install
Postby sonex892. » Sun Sep 15, 2019 6:36 am
Murray Parr wrote:At this stage I am thinking my only option is to drill out the threads in the Rotax bushings and install AN bolts with Nord Lock washers under a Nyloc nut unless anyone has reasons not to do this or has a more successful way to do this. Keep the ideas coming as I am sure others will need this info too
I'm not familiar with the rotax prop mount but providing there is enough thread poking through for a Nyloc nut, could you not just drill out a small portion of the threaded section of the bush so the thread doesn't bottom out in the bush? Then use nyloc nuts. Nyloc nuts with no safety wire does the job on jabiru engined planes. The difference by the sound of it, is the Jabiru bushes are not threaded.
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Murray Parr » Sun Sep 15, 2019 10:23 am
Great idea, I think I will do that (just drill out enough of the threads in the bushing so the bolt doesn't bottom out and then I can have enough threads protruding to install a Nyloc nut).
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Return to Rotax
Users browsing this forum: No registered users and 20 guests
