by sport65 » Wed Jun 26, 2019 6:28 pm
I had the erratic readings also, and found it was the black plug in connector between the fuel probe and the unit itself. With the connector still plugged together, it would have the erratic readings if I didn't hold the plug together with pressure by hand. I used zip ties to hold it together with pressure. I'll see if that works.
Jeff
Sonex 1570, standard gear, matco independant brakes and wheels, aileron trim, MGL iefis, V6 radio, Uavionix adsb, stx-165 transponder, Jabiru 3300
Finished
Ponder Tx
