Safe distance from exhaust
Postby Darick » Wed Jan 04, 2017 5:39 pm
Guys, the oil separator return line (Russel Proflex SS hose) is 3/4" from the wrapped exhaust. Is this too close? Do I need to add a heat shield? I couldn't find a max temp spec for the hose.
Don't mistake the oil cooler hose for the oil separator line. The separator line is a little hard to see but it makes a 180 out of the front of the engine and goes back along side, right next to the engine.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Safe distance from exhaust
Postby mike.smith » Wed Jan 04, 2017 9:28 pm
For the oil line I think you're fine. But adding fire sleeve to all your fuel and oil lines is not a bad idea for safety reasons. It would add another layer against heat as well.
Postby kmacht » Wed Jan 04, 2017 9:56 pm
Looks just like mine and I have had no issues.
You might want to reconsider the separator line though. It looks like a solid line that isn't supported along the side of the engine. The vw vibrates alot. A fatigue crack in that line while flying could empty the whole crank case of oil in short order.
Users browsing this forum: No registered users and 73 guests
