by Darick » Wed Jan 04, 2017 5:39 pm
Guys, the oil separator return line (Russel Proflex SS hose) is 3/4" from the wrapped exhaust. Is this too close? Do I need to add a heat shield? I couldn't find a max temp spec for the hose.
Don't mistake the oil cooler hose for the oil separator line. The separator line is a little hard to see but it makes a 180 out of the front of the engine and goes back along side, right next to the engine.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
