Gripdana wrote:For connection of the warning light. Do I hook one end of the light to the EFIS and the other end goes to power? Is an announciator switch needed or does the light come on during the self test?
Dana Baker
Sonex 1534
Scratch building
Gripdana wrote:Ok. So it works like the oil pressure sending unit? I already drilled the hole for the light. I guess if the display goes out it should work. If I hook up a test switch the switch will be to ground? Thanks for the help.
Gripdana wrote:Thanks for the help. Electronics are not my best area and since the components of the panel are so expensive I don't want to blow something by hooking it up wrong. I'm fishing for a good reason to have that hole for the light I don't really need.
Users browsing this forum: Bing [Bot] and 7 guests
