Securing wires and hoses under the fuel tank
Postby WaiexB22 » Mon Sep 30, 2024 2:23 pm
I have a lot of wires and hoses running from my panel to the firewall. I am routing most of it above the rudder pedals and under the fuel tank. How is everyone securing and organizing stuff in this area?
I am thinking of attaching to the tank straps, but I am hesitant. Are you attaching to the tank straps? If so, how?
I am also considering looking for some kind of attachment I can glue and/or tape to the underside of the tank to secure stuff to. Anyone have anything like this?
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Re: Securing wires and hoses under the fuel tank
Postby GordonTurner » Mon Sep 30, 2024 2:35 pm
I routed that stuff at the sides attaching to the longer one with Adels.
Postby GordonTurner » Mon Sep 30, 2024 2:36 pm
Longeron…
Postby Bryan Cotton » Mon Sep 30, 2024 3:05 pm
Robert,
I bent up a hat section about 2-3" wide. I drilled a couple of holes in the flanges on either side of the tank straps and tie wrapped it up. I'll see if I can find pics, or take one tonight. Works great.
Edit:
viewtopic.php?f=39&t=578&p=46633
Postby WaiexB22 » Mon Sep 30, 2024 7:21 pm
I knew I could count on something from you Bryan! Well done sir! I love this idea.
I can and will use the longerons, but it will not work for a few things. I will use this.
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Postby karmarepair » Tue Oct 01, 2024 12:05 am
High density polyethylene, the fuel tank material, is a bear to dry and glue to, but 3M Very High Bond double stick tape grabs it pretty good. Consumer packaging: http://www.amazon.com/Scotch-Extreme-Mo ... ast_sto_dp
If glue you must, try Cyanoacrylate: When used with Permabond POP primer (which is fantastically expensive), cyanoacrylate can provide good adhesion to HDPE.
karmarepair
Postby Bryan Cotton » Tue Oct 01, 2024 10:00 am
I have found gorilla brand duct tape sticks pretty well to the tank. I use it to hold my LED backlights on the tank for my fuel camera.
Users browsing this forum: Google [Bot] and 35 guests
