Aerovee one EGT high
Postby Bryan Cotton » Sat Mar 23, 2024 4:54 pm
Hey all,
Looking for some thoughts from the Aerovee brain trust. I have one cylinder (#1, back left) going insanely high, like over 1500F. This is during a full power climb. If I enrichen it to get it below 1400, the engine runs poorly as the other cylinders are too rich. The others average about 1200 in climb. In cruise it will run below 1400, but the others are 1000-1200. I have swapped the EGT probe from the #1 and #2 cylinders and the high temperature stays with the #1 cylinder. I've also swapped inputs on the MFD and again the high temperature stays with #1. So I believe it's too hot and I'm not seeing an instrumentation error.
This happens on just the mags, or on both ignitions. I did not try on the secondary ignition only.
I did reseal the left intake manifold, but no change. It seems an induction leak would be a potential cause of a high EGT.
In reading other forums a bad exhaust valve is listed as a possibility, or head gasket, or cylinder issue.
My recent compression test was 116/119/126/125. Last year was 119/121/125/119.
I'm thinking of pressuring the intake with a shop vac to look for a leak with soapy water. Otherwise I'm thinking of pulling the head to have a look.
Any thoughts welcome.
Edit: I also checked the #1 valve last on the exhaust.
Re: Aerovee one EGT high
Postby gammaxy » Sat Mar 23, 2024 6:39 pm
Don't know if this would cause it, but is the exhaust gasket on that cylinder good? I've had to replace them more often than I expected.
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Postby Area 51% » Sat Mar 23, 2024 7:03 pm
Screw the electronics............What story do the spark plugs tell?
Area 51%
Postby Bryan Cotton » Sat Mar 23, 2024 7:43 pm
I'll check the exhaust gasket. They are the originals.
Plugs are coming out, stand by...
Postby n502pd » Sat Mar 23, 2024 11:50 pm
Another thing to look at is the intake manifold gasket security. if one bolt isnt as tight as the other, there may well be just one cylinder sucking air. I have saftied those bolts and have not had any of then come loose any bit. The other thing to consider is the probe may be at fault, if nothing else is found. The plug will also tell you , comparing to one of the other cylinders plug, if cylinder is actually very lean. Pleas e let us know what you find!
Joe Nelsen
scratch built :D
Flying @78.2
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby Bryan Cotton » Sun Mar 24, 2024 8:44 am
n502pd wrote:Another thing to look at is the intake manifold gasket security. if one bolt isnt as tight as the other, there may well be just one cylinder sucking air. I have saftied those bolts and have not had any of then come loose any bit. The other thing to consider is the probe may be at fault, if nothing else is found. The plug will also tell you , comparing to one of the other cylinders plug, if cylinder is actually very lean. Pleas e let us know what you find!
Joe,
I redid the intake sealing on that side, so it was secure. Maybe there is a warp or crack, I'm not sure.
I did swap probes, and the high EGT stayed with cylinder #1.
Postby Bryan Cotton » Sun Mar 24, 2024 10:11 am
secondary plugs.png (260.03 KiB) Viewed 1444 times
Postby pappas » Sun Mar 24, 2024 11:22 am
What are the corresponding CHT's while #1 is displaying the unusual high temp?
Lou Pappas
Phoenix, AZ
RV-7A (Building)
Waiex B Turbo
RV-8
Waiex Legacy 3300
Hiperlight SNS-9
Falcon Ultralight[/b]
pappas
Postby Bryan Cotton » Sun Mar 24, 2024 11:49 am
Lou,
My #1 CHT failed. It reads around 100F after the engine warms up. Pretty much everything else was under 200F. It was cool out. Oil temp was 161.
Edit: I assume it has failed. I'm going to do a differential compression test today.
Postby BRS » Sun Mar 24, 2024 12:37 pm
Bryan, you didn't mention so I won't assume. You did verify both the top and bottom plugs are firing ok - right? Only one plug firing will give a hot egt as fuel burns slower and gets out the exhaust before it's ready.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Users browsing this forum: Bing [Bot] and 22 guests
