Fixing missed rivets
Re: Fixing missed rivets
Postby WesRagle » Mon Feb 05, 2024 9:44 am
Hi Guys,
That wasn't at all what I expected.
I don't want to be too pessimistic, but zoom in on the rivets of the "wide angle" shot. It may just be the way I'm looking at it but the rivet holes look to be badly over-sized. It looks like one of the pulled rivets doesn't even reach the edge of the hole.
I'm also curious about the aileron push rod. Mine were steel with high gloss black paint. I don't remember any "Made in USA" marking.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Bryan Cotton » Mon Feb 05, 2024 10:24 am
I can't tell if the holes are oversized, but I hope that aileron pushrod is not conduit.
Postby dbdevkc » Mon Feb 05, 2024 10:26 am
Wes
!!! What is that "MADE IN USA" pushrod/shaft/tube material? !!! Not factory supplied pushrod as far as I can tell.
[color=#800000]Kevin Conklin
Building Waiex #169
dbdevkc
Postby Area 51% » Mon Feb 05, 2024 10:40 am
I have several sizes of 6061-T6 tube and all are marked Made in USA. No such markings on any of the steel tube I could find.
Area 51%
Postby WesRagle » Mon Feb 05, 2024 11:14 am
Hi Guys,
Maybe it is conduit for wiring.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby 13brv3 » Mon Feb 05, 2024 9:09 pm
I'm with Bryan in thinking it was just an assembly error. As he said, it was drilled and dimpled, but just moved out of position when they riveted. Easy fix, and if that's the worst thing you find, you're in good shape.
As for that aluminum tube, I'm assuming that's wiring conduit. I could have used that today running wires to my lights.
Rusty
Onex- Rotax 912 (135 hours and counting)
Fixed wing, gyroplane, A&P
13brv3
Postby Murray Parr » Tue Feb 06, 2024 2:00 am
dbdevkc wrote:
Wes
I have the B model and the Aileron pushrods are Aluminum just the same as Vans uses. Maybe the Onex uses Aluminum too.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby WaiexB22 » Tue Feb 06, 2024 10:53 am
The b model aileron pushrods are aluminum and they look like conduit. They look like the ones in these photos. I wouldn't be surprised if the onex is the same.
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Postby 13brv3 » Tue Feb 06, 2024 12:48 pm
Unless they changed it, which I highly doubt, the Onex uses steel pushrods. Also the picture that shows the conduit says second rib in from tip, meaning the outer wing panel. It's not an aileron pushrod.
Rusty
13brv3
Postby VillaAir » Wed Feb 07, 2024 9:47 pm
Thanks for the help!
It's going to take a little while to get to, but I'll post pics when it's fixed.
I've been going over the build with a fine tooth comb. So far, other than a few wire connectors, this is all that I've found.
I'm going to have my IA do the conditional in a month or so and we'll see what he finds
VillaAir
Return to Onex
Users browsing this forum: No registered users and 25 guests
