Bryan Cotton wrote:I think if I build another Sonex ever I would put a nutplate in the cabin, and use a bolt with a head drilled for safety wire. If it wasn't such a pain to work on the firewall I'd put it in now.
builderflyer wrote:Bryan Cotton wrote:I think if I build another Sonex ever I would put a nutplate in the cabin, and use a bolt with a head drilled for safety wire. If it wasn't such a pain to work on the firewall I'd put it in now.
?? Did you use safety wire on the bolts attaching the vertical stabilizer?..........Oh wait, you built a Waiex. Just wanted to point out that there is no safety wire called out for the heads of the bolts that attach the vertical stabilizer on the Sonex. Nutplates by themselves have self "locking" qualities. But I have put torque seal on the heads of these bolts to satisfy myself that they haven't loosened since the last inspection.
Art,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,Jabiru 3300 #261
N111YX wrote:Bryan, my gear bolts go in pointing aft, washers make up the distance to the firewall, and the castle nuts are on the cabin side of the firewall. It works well. The torque on the nut is minimal so there is no need to go so tight as to crinkle the firewall. There seems to be a good seal from the washers.
Users browsing this forum: Google Adsense [Bot], Wanttobuild25 and 182 guests
