Murray Parr wrote:I have been doing the Pitot Static testing using the MGL Explorer light IEFIS TAS values against its GPS ground speed values flying up and back a coarse perpendicular to the wind direction and averaging the speeds.
I am finding the following:
- Low speeds 50KTS the TAS reads slightly low 1 to 2 knots difference after averaging out.
-65 knots has no error.
-80 knots the TAS reads 7 knots high.
-120 knots the TAS reads 16 knots high.
I am using the standard Sonex pitot/static probe in the standard location.
I had the system leak tested and calibration checked before first flight and all was leak free and 100% accurate.
I tried opening the alternate static port and saw no change in the speed readings.
Given the above, what is the most likely cause of the speeds reading slightly low at lower speeds and reading high at the higher speeds?
I thought if the static was not right it would read either too low or too high at any speed? I also feel that when the calibrations were done, all speeds were 100% accurate, so it shouldn't be possible for the pitot probe to be feeding more pressure in than available or do I have this theory wrong?
Any advice on where to start is greatly appreciated.
Users browsing this forum: No registered users and 36 guests
