Rotax Sonex
Rotax 912 series discussion.
Re: Rotax Sonex
Postby gcm52 » Tue May 26, 2020 5:41 pm
By the way I have been running the engine on the ground to adjust the prop pitch and the engine runs strong and smooth. Fires up as soon as I push the start button.
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Re: Rotax Sonex
Postby 13brv3 » Tue May 26, 2020 8:03 pm
gcm52 wrote:When I moved the engine, I moved the CG of the Rotax engine 7 inches forward of where the CG of the aerovee engine was. I tried to keep the thrust line the same. To allow a larger diameter prop, which is necessary with the Rotax, I lengthened the nose strut by three inches. I have a 64" diameter Warp Drive prop on it now. I am toying with the idea of putting on a four blade Warp Drive just for fun. I also am probably going to remove the 1" prop extension on there now as I actually don't need it for cowl clearance. Attached are a couple more FWF photos so you can see what I did. I used a Rotax ring mount and designed a custom mount going from the ring mount to the firewall.
George
Thanks for the additional info George. 7 inches of movement for the CG is definitely out there. My best estimate shows about 3.5" of CG move, which makes the prop about 6.5" forward of the normal location. since it's easier to fix nose heavy, than tail heavy, I'll probably shoot for 4" of CG movement. For the tailwheel version, with standard gear, I'll likely end up with a 4 blade Bolly (sold by Hoverhawk). I won't make a decision until the engine is mounted and the prop clearance is known.
Rusty
PS- Sorry to Jake for all the Onex chat on his Sonex thread.
Rusty
Onex- Rotax 912 (135 hours and counting)
Fixed wing, gyroplane, A&P
13brv3
Re: Rotax Sonex
Postby SonexN76ET » Fri Feb 03, 2023 8:38 pm
Next week I will make my first flight after repowering my Sonex with a Rotax. It has taken me three years and close to 600 hours, most of which has been spent on customizing the cowling. Everything firewall forward is new. I also put the smaller nose wheel pants on the main gear and had to modify those to fit around the brakes. Once again I have the first flight anticipation.
Jake
Sarasota, Florida
SonexN76ET
Re: Rotax Sonex
Postby SonexN76ET » Fri Feb 03, 2023 8:47 pm
Side view:
Jake
Sarasota, Florida
SonexN76ET
Re: Rotax Sonex
Postby Bryan Cotton » Fri Feb 03, 2023 9:26 pm
Awesome! Good luck!
Re: Rotax Sonex
Postby MichaelFarley56 » Sat Feb 04, 2023 11:24 am
Congratulations on finishing the swap Jake! The Sonex looks great and I can’t wait to hear how she flies!
Please let us know how the test flights go and enjoy!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Re: Rotax Sonex
Postby Skippydiesel » Sat Feb 04, 2023 5:28 pm
Hi Jake - Great looking cowling. I would be very interested to see some photos of how you have managed your cowling exit air.
Skippydiesel
Re: Rotax Sonex
Postby Skippydiesel » Sat Jun 03, 2023 2:12 am
Hi Jake,
Any cooling problems?
I would still like to see how you have managed your cowl exit air ?
Skippydiesel
Re: Rotax Sonex
Postby Skippydiesel » Sat Jun 03, 2023 2:14 am
Hi again Jake,
What Radiator & Oil Cooler are you using?
Skippydiesel
Return to Rotax
