Oil Filter inspection
Postby JohnBlackstone » Fri Oct 14, 2022 12:00 pm
What are you guys using to cut open and inspect your Fram oil filter?
JohnBlackstone
Re: Oil Filter inspection
Postby Jgibson » Fri Oct 14, 2022 7:24 pm
I have a cutter that screws into the filter and as you turn the filter, a cutting wheel cuts around the outside of the can. Sort of like a pipe cutter works, except the filter screws onto the tool. It has an adapter for either type of filter either with a male threaded nipple or a female threaded hole.
Joe
Jgibson
Postby Skippydiesel » Fri Oct 14, 2022 8:27 pm
Skippydiesel
Postby Kai » Fri Oct 14, 2022 10:47 pm
My EP915ECI engine has just passed 50 hrs, and is still well within warranty.
So I fly over to the Edge Performance facilities and do oil- and filter change there. They have developed their own filter can cutter, which I can borrow. When I have the internal paper filter element out, Edge checks it out for me.
Works like a charm!
Kai
Postby daleandee » Fri Oct 14, 2022 11:39 pm
[quote="Skippydiesel"]Recommendations from another web site :
https://www.youtube.com/watch?v=zrH92W6ODy4
I saw this a couple of years ago and now use this method. It is quick, and fairly easy to do. For those that built their plane ... the odds of of a set of aviation snips being somewhere in the hangar is very high!
Postby bvolcko38 » Sat Oct 15, 2022 8:59 am
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby JohnBlackstone » Wed Oct 19, 2022 8:18 pm
Thanks, Skippy and Dale and the rest of you. I think I’ll try the tin snip method before the other solutions.
JohnBlackstone
Postby BRS » Wed Oct 19, 2022 9:41 pm
JohnBlackstone wrote:Thanks, Skippy and Dale and the rest of you. I think I’ll try the tin snip method before the other solutions.
;-) I don't recommend the tin snips. But go ahead and use them, once.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby daleandee » Wed Oct 19, 2022 11:17 pm
It literally takes about 30 seconds to open the filter with a good pair of snips. Have you tried this? I'm curious as to why you don't recommend them. It's very quick, easy, doesn't contaminate the filter, and most builders may already have the snips in the shop.
I have no heartburn with using a high dollar filter cutter if that's what one wants to use.
Best ...
Dale
3.0 Corvair - Taildragger
Postby Kai » Thu Oct 20, 2022 2:35 am
Previously I tried the tin snips way several times on automotive filters with good results.
Now I have a R912 type hanging up front, and I had to throw in the towel (and the snips). It seems that the R912 filter is a magnitude more resilient than the others.
Hence the more dedicated filter cutter.
Kai
Return to Jabiru
