Location of headset jacks/plugs
Postby Skippydiesel » Fri Dec 10, 2021 5:51 pm
Just got to the stage of installing headset female jack/plug points. Having difficulty with making the decision of where to place them. What have you done (photos would be great ???
Skippydiesel
Re: Location of headset jacks/plugs
Postby WesRagle » Fri Dec 10, 2021 6:11 pm
I like the headset jacks behind me out of the way. So, I located the jacks on the backside of the rollover bulkhead and just toss the wires over my shoulder into the baggage compartment while getting strapped in.
The only pic I have.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby mike.smith » Fri Dec 10, 2021 8:26 pm
http://www.mykitlog.com/users/display_l ... 274&row=88
Wires are below the level of the structure so don't get smacked, and they don't hang off the panel in my lap.
Postby BRS » Fri Dec 10, 2021 8:35 pm
Wes, looks like the 'ring' (ground) of your jacks are grounded to the airframe. That is an avionics no/no. Do you have any trouble with them like that?
Skippy, my solution might not be possible for most folks. What I like about these is that they are easy to get to and the plugs are tucked against the side so they don't get in the way. See them there on the sides.
-Brock
Sonex-A (s/n 1013)
R2300, P-tip 54/50
Center Stick
V16, TT22
BRS
Postby WesRagle » Fri Dec 10, 2021 9:38 pm
HI Brock,
BRS wrote:Wes, looks like the 'ring' (ground) of your jacks are grounded to the airframe. That is an avionics no/no. Do you have any trouble with them like that?
What is shown in the pick are extension sockets for the hand held radio I'm using.
I've never given it much thought but It might be electrically different than a normal jack. It's never been a problem. Always gotten a loud and clear when I called for a check. Early on one of the guys I asked didn't answer but another guy 60 miles away did. At first I thought I had a problem but it was just silly me having the squelch disabled.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Prince P Tip 54x50
WesRagle
Postby Bryan Cotton » Fri Dec 10, 2021 10:52 pm
My documentation and pics can be found here:
viewtopic.php?f=39&t=578&start=1180
Mine are wired cross cockpit. Much easier to plug in on the other side. I also hang my headsets up on the opposite side.
viewtopic.php?f=39&t=578&start=1170
Postby taildragger » Sat Dec 11, 2021 12:03 am
I'm putting mine behind the pilot, to declutter the cockpit.
Building electric Xenos
President, EAA Chapter 1250
taildragger
Postby Skippydiesel » Sat Dec 11, 2021 1:27 am
taildragger wrote:I'm putting mine behind the pilot, to declutter the cockpit.
Sounds like a good idea. Same concept as WesRagle.
I would like to come up with a design/location that;
[list=]Has the jacks/sockets behind pilot/passenger, to keep as much of the headset leads out of the cockpit as possible
Incorporates a headset "hook"/stow point.
Minimises the chance of damage to plug/socket.
Covers all the electrical wiring & back end of socket
Accessible in flight should a plug come loose/not quite making contact [/list]
Skippydiesel
Postby Bryan Cotton » Sat Dec 11, 2021 10:53 am
This is what my design does.
Postby Skippydiesel » Sat Dec 11, 2021 5:17 pm
Very nice Bryan - Can you post a photo of headset plugs in sockets, looking from the front of the aircraft back ?
I would like to have an idea of how much/far the plugs project into the baggage area.
Skippydiesel
