Tool to tighten head bolts under rockers
Postby Brian Bange » Thu Nov 18, 2021 2:26 pm
Hi, new to the forum. I purchased a 23 hour Sonex and need to re-torque the head bolts @ 25 hrs. Does anyone know where I can get the tool that allows me to get to the head bolts under the rockers? Brian
Brian Bange
Re: Tool to tighten head bolts under rockers
Postby MichaelFarley56 » Thu Nov 18, 2021 4:37 pm
Congratulations on the purchase of your new Sonex Brian! I hope you love the airplane!
I’m not sure of any tools that will work for you. The standard is to remove the rocker assembly, torque the head bolts, reinstall the rocker assembly and finally check the valve clearance. It’s not a quick job but pretty straightforward.
Good luck!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby GraemeSmith » Thu Nov 18, 2021 10:38 pm
I do it with a crowsfoot that you can get under the rocker and that fits on a socket extemsion. And a bit of math because it's now on a small lever that Changes the actual torque measurement
Graeme JW Smith
GraemeSmith
Postby jerryhain » Fri Nov 19, 2021 1:23 pm
You can get crowsfeet from harborfreight or most tool stores. If you have the foot at 90 degrees no math needed.
Jerry Hain, Tucson AZ
Waiex Electric?
jerryhain
Users browsing this forum: No registered users and 78 guests
