Electric Xenos-B Electric Quick Build
Discussion for builders, pilots, owners, and those interested in building or owning a second generation Xenos.
Re: Electric Xenos-B Electric Quick Build
Postby taildragger » Sun Sep 26, 2021 9:54 pm
Thanks for your advice. Since it's a quick build, Sonex is building the wings and fuselage. Did you say I could pay Sonex for flush rivets?
Building electric Xenos
President, EAA Chapter 1250
taildragger
Postby racaldwell » Mon Sep 27, 2021 8:40 am
TD,
Yes, for the kit I know because I did that. I forget how much; that was around 2015. It is probably still listed on their options selection on their website or order form. For the QB, I don't know. Dimpling & c'sinking adds to the labor so it is no longer just a parts change. Sonex can answer that question.
Rick Caldwell
Xenos 0057
racaldwell
Postby taildragger » Mon Oct 25, 2021 5:19 am
Progress:
- Tail kit arrives tomorrow. Will pick up at XPO Logistics.
- Workshop shed arrives Nov 9
- Bought a horizontal / vertical band saw, table top belt sander
- Ordered climate control system: A Mitsubishi 9K BTU mini split heat pump. SEER 30. Heats down to -13F.
- Have pegboard organizer hardware
Any advice on how to inventory the tail kit?
taildragger
Postby taildragger » Sun Nov 07, 2021 11:20 pm
Yay. Assembled my first pieces: Right and Left Hand Root Rib Assembly with 120 degree countersink drill and rivets. Questions:
1) One 1/8th 120 degree countersink drill plunged about 1/32 too far into the hole; I'm not sure why since it was on a plunger. One countersunk rivet of 23 is probably slightly weaker than the rest. Should I leave it alone or drill it out and put a slightly larger countersunk rivet in?
2) I'm confused by the Xenos Ruddervator Skin drawing page 9. Am I allowed to post an annotated photo of that portion of the drawing on this forum or is that totally illegal?
taildragger
Postby racaldwell » Mon Nov 08, 2021 2:38 pm
I would leave the oversunk rivet as it is. Potentially wallowing out the hole getting the rivet out would be worse.
I've seen sections of drawings so it should be no problem. But I am not the authority on the subject.
Rick Caldwell
Xenos 0057
racaldwell
Postby taildragger » Tue Nov 09, 2021 11:03 pm
Made a hinge drill / index tool with aluminum tabs and oak. All holes are drilled identically.
taildragger
Postby taildragger » Fri Jan 21, 2022 6:17 am
taildragger
Postby GraemeSmith » Fri Jan 21, 2022 7:28 am
Graeme JW Smith
GraemeSmith
Return to Xenos-B
