Hi Peter,
Good to hear from you again! I'm glad you're still refining and optimizing your EFI system! I've been slowly gathering the materials for a conversion myself, and hope to try it out eventually.
I bought these injectors based on another Sonex builder's experience, and they simplify the plumbing somewhat. The unit is actually two parts - the injector itself (the purple part) and the housing with the mounting boss, hose nipple and wiring plug.
![s-l1600.jpg](./download/file.php?id=3457)
- s-l1600.jpg (42 KiB) Viewed 4063 times
The injectors were purchased from ebay, and are replacement motorcycle injectors rated at 120 cc/min (a little high, but reportedly works OK for an 80 HP engine).
https://www.ebay.com/itm/274442493663?ul_noapp=trueHoses connect directly to the injector without the use of a fuel rail, but that means you can't create a continuous loop for the fuel flow (a bit of a tradeoff). Instead, you'll have a manifold that receives fuel from the pump and then splits to each of the 4 injectors, plus a return line to the fuel pressure regulator and back to the tank. SDS makes a nifty billet machined fuel manifold, and that's what I plan to use.
![block22.jpg](./download/file.php?id=3458)
- block22.jpg (44.27 KiB) Viewed 4063 times
http://www.sdsefi.com/sdsaero.htmWhile you're at it, you might buy the fuel pump and pressure regulator from SDS as they are high quality units. Whether you buy the SDS computer, Microsquirt, or roll your own is up to you. I plan to keep the AeroInjector installed for use as the throttle body (mixture knob at idle-cutoff), plus plumbed for fuel as a manual backup to the EFI (mixture knob full-rich).
Jeff
