Xenos 59 Electric Build
Re: Xenos 59 Electric Build
Postby Xenos 59 » Mon Nov 09, 2020 1:14 am
Bob flew the Xenos over 2 hours and covered 130 miles and landed with ~1/2 battery today :)
https://www.youtube.com/watch?v=7RXVSk-B-MY
Xenos 59
Postby Matt541 » Mon Nov 09, 2020 8:53 am
Too cool Gabe!
Matt541
Postby XenosN42 » Mon Nov 09, 2020 10:48 am
Wish I could fly over that landscape. Nothing but mountains, trees around here.
-- Michael
OneX N169XE
XenosN42
Postby Xenos 59 » Fri Dec 04, 2020 1:18 am
I cannot recommend a Zero powered Xenos enough :)
Xenos 59
Postby ASDomenighi » Thu Dec 24, 2020 2:59 am
Gabe, how are the flight testing going. Is been great watching your flights on you tube. Do you have already some numbers on how many kWh takes to fly to 2,000 or 8,000 feet and how many kWh to maintain level flight ?
Again congratulations on the progress, and with the new site http://flitllc.com/
ASDomenighi
Postby Xenos 59 » Fri Jan 08, 2021 3:29 am
It's pretty close to 10% battery per 1000' of climb. It's about 9kW for level cruise at 60mph IAS.
Xenos 59
Postby ASDomenighi » Tue Feb 02, 2021 10:15 pm
Gabe, thanks for the info, this is very good, if I remember correctly on your e-ultralight you were cruising at 8kW, just 1 kW more for the Xenos is good !!
On the DEAN SIGLER Blog I read that you are working on the Michael Friend’s Spark Solo with 2 Zero 14.4 kW batteries, will be nice if we can come up with the possibility to install 2 14.4 kW on the Xenos too. Do you think that this is possible ?
Great work is always very good to know the progress that you are bringing for a practical electrical implementation on the experimental aircraft !
ASDomenighi
Postby Xenos 59 » Wed Feb 03, 2021 2:36 pm
Yes it is possible to use two 14.4 batteries. But for gross weight and CG reasons it would have to go in the passenger seat. I am considering adding the modification later to enable long range solo flights. This would increase the range and duration to about 150 miles and 2.5 hours. Right now I am adding an extra 3.6 battery which will still work with CG and weight limits including about 450lbs useful load! This will bring the range and duration to about 100 miles and 1.5 hours.
Xenos 59
Postby Xenos 59 » Sat Feb 13, 2021 4:45 pm
Xenos 59
Postby Xenos 59 » Sun Apr 25, 2021 5:42 pm
My Zaero Re-Drive kit is now available for purchase!
https://flitllc.com/
Xenos 59
Return to Xenos
