average CG location?
Postby 13brv3 » Tue Apr 14, 2020 7:36 am
Greetings,
I'm in the process of trying to calculate the length of the engine mount for my 912 Onex installation. One variable that I don't know is how the CG tends to work out on a normal Aerovee Onex. If you have completed an tailwheel Onex, can you share your CG location? If they tend to be nose heavy, or tail heavy on average, I'd take that into account when building my mount.
Rusty
Rusty
Onex- Rotax 912 (135 hours and counting)
Fixed wing, gyroplane, A&P
13brv3
Re: average CG location?
Postby XenosN42 » Tue Apr 14, 2020 9:59 am
Hi Rusty,
Here are the numbers for my OneX 169. The datum is as defined in the OneX flight manual. Let me know if I've left out any important data.
Empty weight: 627 pounds
Arm: 59.94 inches
Moment: 37,584.8 inch/pounds
Engine: AeroVee 2.1 (normally aspirated)
Gross weight: 950 pounds
Arm: 63.60 inches
Moment: 60,419.3 inch/pounds
CG is 26.2% of MAC
-- Michael
OneX N169XE
XenosN42
Postby WesRagle » Tue Apr 14, 2020 11:41 am
Hi Rusty,
If you go to the 31 minute point of this webanar it might give you some ideas, https://www.youtube.com/embed/wV_cqkweNzg.
CG Limits 20-32% Wing Chord
Hummel 2400 with bits for cold air induction, after market (heavy) main gear and baggage compartment.
Empty weight 638.5 lbs.
Empty CG is 58.71" aft of the spinner tip which works out to 7.835" aft of the leading edge or 15.67 % wing cord.
I can't go aft CG with me, empty fuel, and lots of baggage with out going over gross when I fill up.
Full fuel,a 150 lb. pilot, and no baggage goes just a tad forward of the forward limit.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Gordon » Tue Apr 14, 2020 2:03 pm
Onex C.G.
I have the Hummel 2400 85 hp. engine, Odyssey PC-680 battery and 5:00x5 tires which are heavier.
Short answer ….with full fuel and my 175 lbs my c.g. is only 3/4" from the fwd limit.
Hope that helps.
Gordon...…..Hummel 2400....Onex 0024
Gordon
Postby 13brv3 » Tue Apr 14, 2020 5:12 pm
Appreciate the numbers, and the link to the webinar. I added "tailwheel" to the request, since it does seem to make a difference. I know Wes is tailwheel. I'm assuming Michael and Gordon are as well?
If anything, I'll likely lean toward being a little noseheavy, since that's safer, and can be corrected with much less added weight if needed.
Rusty
Rusty
13brv3
Postby XenosN42 » Tue Apr 14, 2020 6:44 pm
13brv3 wrote:Appreciate the numbers, and the link to the webinar. I added "tailwheel" to the request, since it does seem to make a difference. I know Wes is tailwheel. I'm assuming Michael and Gordon are as well?
Rusty
Hey Rusty,
About 10 minutes after I wrote my post I remembered that I should have added that my airplace has a tailwheel.
I agree that a little nose heavy is better than tail heavy. In my aircraft I've never had to use full stick forward or aft. I don't fly aerobatics.
-- Michael
OneX N169XE
XenosN42
Postby N21X » Fri Apr 17, 2020 2:45 pm
Im planning on putting a 190 lbs ish engine with standard mount, I already mounted pc540 on firewall. Going to pay close attention to more replies with what others have.
CFI, CFI—I, MEI, MEI-I, ATP, A&P
US ARMY Veteran
Rv9a - Flying
Rv3a - Flying
Onex #165 (Flush riveted w/AM 13 AEROMOMENTUM 127hp & a 59” 4 blade prop)
N21X
Postby 13brv3 » Sat Dec 11, 2021 10:47 am
I finally made it to Weight and balance time, so I figured I'd report the results. I'm very happy with the way this came out, which was part luck, and part calculation :-)
Rusty
N64RD 121021 WB.jpg (115.16 KiB) Viewed 2513 times
Rusty
13brv3
Users browsing this forum: No registered users and 45 guests
