Rynoth wrote:The only guarded switches I've ever seen in airplanes (and they are few and far between) are switches that, if flipped, might do something irreversible. I can't think of a switch in my Waiex that, if flipped, would cause a problem that wouldn't be solved by simply switching it back.
Spaceman wrote:If you kill the engine by shutting all the ignition off, like in the pattern, will it fire right back up when you turn everything back on? Will an Aerovee windmill at pattern airspeed? Honest question, I have no idea!
Users browsing this forum: Google [Bot] and 10 guests
