After about 60 hours, the parking brake feature stopped working due to wear.
- Damage on brake lever.jpg (67.28 KiB) Viewed 1866 times
I cut out the damaged area and made a stainless steel wrap.
I really like the brakes and the parking brake design is simple and easy to use. There is a stop you can pull past and it holds the lever, as per the Sonex plans. I am hoping the stainless will solve the wear problem.
