WesRagle wrote:Hi Guys,
I'm still moving along (at a glacial pace).
I covered and installed the glare shield and fuel vent. I may regret the covering the first time I spill fuel but I shall endeavor not to spill.
I also did some final trimming on the cowl. Since nobody would venture a guess as to the movement of the engine relative to the cowl, I made a guess. 1/4" top and sides and 1/3" on the bottom for a firm landing. I'll just have to keep an eye on it to see if that's adequate. I will attempt a jam seal (form the back) around the induction tube using a block of foam. If that doesn't work I'll come up with something else. Maybe try a more refined approach once the plane is flying and I need something to do.
I need to order fasteners. I prefer quarter turn fasteners. I'm thinking of these https://store.skybolt.com/phillips-sk28s3-series-c1207.aspx. Any advice appreciated.
BTW, UPS just delivered a sheet of 0.016. Now I have no excuse not to attack the baggage compartment.
Wes
Onex107 wrote:Don't joke about spilling fuel.
WaiexN143NM wrote:Also i used contego fire barrier(aircraft spruce) on the inside of cowl. looks and smells like white latex paint. with a fire barrier additive.
You’ve got a nice quality build. Keep plugging away!
WaiexN143NM wrote:I used the following parts:
SK213-2 Receptacle
ZG28S3-2 fastener
SK2600-LWS fancy washer (Bill is correct. Buy extras)
4P3-T26 Stupid expensive tool to push fancy expensive washers onto fasteners
SK245-PK silly expensive tools used to fuss with fancy expensive washers and receptacles
I am willing to LOAN them with the clear understanding they are to be returned.
As far as what happened to my prop - no idea what actually happened, but it is likely a fastener popped a fancy expensive washer and flew out into the rear face of my prop. That or a rock on the runway.
I am curious if the crazing/cracking of lexan is related to how well the cut edges are polished out. I think I'll take a little more time and polish the hole and cut edges down to 2000 grit.
wlarson861 wrote:Take a scrap piece of Lexan(trimmings from the windshield) and bend it to a radius similar to the windshield and have someone pour a little auto gas on and watch it crack everywhere the fuel touches.
Users browsing this forum: No registered users and 29 guests
