Onex107 wrote:When the flight recorder worked in my Extreme it was great. You could graph every variable. But, the data recorder stopped recording. It is set for automatic recording at low rpm's and air speeds. Even a new data card didn't solve the problem. Any ideas?
WannaFly wrote:Onex107 wrote:When the flight recorder worked in my Extreme it was great. You could graph every variable. But, the data recorder stopped recording. It is set for automatic recording at low rpm's and air speeds. Even a new data card didn't solve the problem. Any ideas?
One thing that got me.... You have to have the "enigma.rec" file already on the sd card. After I recorded my first flight I transferred everything on the card and deleted it....couldn't get the data of the extreme ever again....I was forced to read the manual and found it in there somewhere...
Users browsing this forum: flyguy0609 and 1 guest
