Rynoth wrote:The guidance reads:
(1) On both sides of the
fuselage between the
trailing edge of the wing
and the leading edge of the
horizontal stabilizer, or
(2) On both sides of the
vertical tail surface.
Since the stabilators are more horizontal than vertical I doubt it would be acceptable to place the numbers on them. And assuming they are "horozontal", it would have to be forward of their leading edge. The stub-rudder on the other-hand might be viable, but I don't think a standard 6-digit number of appropriate dimensions would fit, however a shorter N-number (fewer digits) might fit if you can get one. Then again, the stub-rudder is more of a control surface than a tail, so that argument might also go both ways.
This is a good question, I wonder what others' opinions might be.
Users browsing this forum: Google [Bot] and 12 guests
