John Monnett wrote:Michael,
"John Monnett wrote:
that is the number one reason that at nearly 75 I am still involved at the heart of this endeavor but continue to marvel at armchair "experts" that have to express their opinions on this forum regardless of their knowledge, experience, agenda or just plain ignorance."
I am sorry you misunderstood my comments about a "hand full of posters". I believe you took it as a personal attack probably because it was awkwardly placed in my response post. I was trying to convey to you and the members of this group the frustration felt by myself and my team at Sonex about such posters described above that post with impunity. The comment should have been made in separate post so as to not confuse the issues.
In no way was this comment directed at you an accusal, a criticism of you, or a demeaning of your efforts and contributions. Of course you are a very valued and appreciated member of the Sonex family. I again apologize!
We will however, find a better way to test the fan than flying in foggy and rainy conditions. ;)
kevinh wrote:Cool beans Mark.
A few questions based on these initial instructions:
* For legacy airplanes it recommends mounting the radiator vertically on the left side of the engine mount. Why is this? Is it because there isn't enough space up at the top of the firewall because of the filler neck?
* For a vertical mounting what do you think of putting the vent holes on the left side of the cowl? It seems to me that the fan is providing virtually all of the cooling benefit (vs having the vents on the top and convection)
* Have you considered using the version of the VDO oil temp sender that also has the switch for the "idiot light" for oil pressure failure? It seems to me that that switch could be wired in series the the thermostat switch, allowing an installation that doesn't require a new switch or pilot actions to enable the fan on shutdown.
I've ordered most of the pieces and will start test fitting on my not yet flying plane. ;-)
markschaible wrote:
Sonex Aircraft has begun flight testing of the new AeroVee Turbo Liquid Cooling System with great results. https://www.sonexaircraft.com/aeroveeturbo_update_030518/
Mark, can you give any insight as to how long the pump is running post-shutdown when running off the thermostat switch? For the sake of simplicity, I'm considering a simple timer switch that I can just set to 10-15 minutes, tied into my hot battery bus. This achieves the objectives of 1) not running during flight and 2) run for a set time after shutdown, without any concern about draining my battery if the pump runs too long.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 10 guests
