kmacht wrote:One thing to remember is that pictures of just a part aren't worth much. You need to show pictures with you in it making the parts to prove you built the plane.
Keoth
Good caution, but working alone, only photos of myself even in same room where plane was built, were a few where I can be seen reflected in polished surfaces while taking the photos. Neither the DAR nor the FAA examiner that I saw in the FAA's regional office when applying for the repairman's certificate had any problem with that. May be different elsewhere.
