Onex33
Onex33
Postby lgsievila » Wed Jul 20, 2016 9:55 pm
Removed AeroVee and installed 2200 CAMit with standard 20 amp alternator and inhibitor. Had to do some wiring changes to accommodate Dynon Skyview. Engine moved forward as it is lighter and lots of work on the cowl.
http://imageshack.com/a/img924/8962/hY9wjw.jpg
http://imageshack.com/a/img921/3562/8rIlWF.jpg
http://imageshack.com/a/img924/5741/wG8K2m.jpg
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
lgsievila
Re: Onex33
Postby GordonTurner » Thu Jul 21, 2016 2:10 am
Sweet!!!!
GordonTurner
Re: Onex33
Postby Brett » Thu Jul 21, 2016 4:54 am
I'm super curious to know, have you flown it yet with the new engine and if so were there any performance gains with the cammit?
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Re: Onex33
Postby lgsievila » Thu Jul 21, 2016 9:38 am
Haven't flown yet-just finishing weights and balance. Coming in 32 pounds less than AeroVee I would expect some performance improvements.
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Re: Onex33
Postby gcm52 » Thu Jul 21, 2016 10:03 am
How far forward did you end up moving it?
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Re: Onex33
Postby JT1974 » Thu Jul 21, 2016 2:10 pm
Nice Job with the Camit installation. I'm looking forward to seeing your plane flying with the Camit on YouTube. Maybe a "walk-around" video showing the engine installation would be great if you get a chance.
Jason T
Onex 182
JT1974
Re: Onex33
Postby lgsievila » Fri Jul 22, 2016 12:53 pm
Thanks Jason-I'll do a video walk around. The engine mount is 9 inches longer (20" vs 11")than the AeroVee mount and the tip of spinner is about 7 inches further forward.
Loren
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Re: Onex33
Postby x3 skier » Fri Jul 22, 2016 6:27 pm
Beautiful paint scheme. Is that a jet ski trailer?
Cheers
Onex 202, Finishing Fuselage Kit, Controls/Gear/Engine Config kit delivered.
x3 skier
Re: Onex33
Postby lgsievila » Sat Jul 23, 2016 1:01 am
No it is a boat trailer that hauled a 21 ft SeaRay that I converted to haul the Onex. The ramp lowers down and I can load it myself in about 5 minutes. Another 15 minutes to tie it down and I am ready to go. I have a hangar at the airport which is about 14 miles on side roads from the house but I prefer to take it home for maintenance/annuals etc especially in winter when I can work in my heated shop. My friend also uses it to haul his Onex to his house as needed.
Thanks
Loren
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Return to Photo Album
Users browsing this forum: No registered users and 20 guests
