142YX wrote:there should be virtually zero resistance in turning, and virtually zero slop or chatter in the assembly.
MichaelFarley56 wrote:I think I ended up using one or two thin sheets of paper to make mine just a little snug and to ensure there was no "slop" in the assembly. I tried to do that with most of the brass bushings found throughout the airframe going under the assumption that the bushings would loosen up just a fraction through normal use over the first 100 hours of flight time.
As long as there's no slop you should be fine.
Users browsing this forum: No registered users and 70 guests
