by 13brv3 » Fri Oct 16, 2015 5:18 pm
Greetings,
I'm set to build a Onex when the kit arrives, and of all the engines I've tinkered with in my life, I've never used a VW (or similar). I've read, and searched through the forum, but I do have a couple general questions if you don't mind.
1- What would be considered a "normal" time between corrective maintenance on one of these engines? I'm referring to overhaul type work (rings, valves, etc). I've seen some really low numbers (double digits) thrown around, though I do realize that people often go back into the engine for other reasons not related to wear (changing compression, oil leaks, etc). I have to believe the expectation will be at least a couple hundred hours between overhauls. Does that sound correct? I realize overhauls are cheap, and relatively easy, and I'd be satisfied to do it at every annual if needed.
2- Since I'm considering a turbo option, would you expect turbo use to make the overhaul time worse? I'm thinking it would, since generally more power means more wear.
3- Is there an explanation posted that states why they don't use outside ram air for the intake? Using warm air seems wrong, but with the amount of air that likely flows through the cowl, maybe the air temp really isn't that high in flight? Still, cooler ram air would have to add a bit of power. Using under-cowl air seems like giving away HP, so I'm wondering if there's a reason it isn't done, other than convenience?
Rusty
Rusty
Onex- Rotax 912 (135 hours and counting)
Fixed wing, gyroplane, A&P
