Hi Roy,
This post is a little late, as I see you solved your problem with the aileron push-rod. I experienced the same problem last year on Onex 0095, but fortunately that happened before I closed the wing. I also had to widen the hole inboard just a bit.
- Hole in spar for aileron push-rod
- IMG_1735a.jpg (70.95 KiB) Viewed 3901 times
There is another problem related to the aileron push-rod that you might be interested in. Depending on the manufacturer of the rod-end bearing, the possibility exists of the shoulder of the bearing interfering with the bellcrank at the pivot point. Took me a while to recognize this as a problem, as it did not show up until I tightened down the nut at the interface point.
- Aileron bellcrank interference with rod-end bearing
- IMG_1563a.jpg (78.69 KiB) Viewed 3901 times
This can be fixed by modifying the bellcrank as shown here.
- Modified aileron bellcrank
- IMG_1558a.jpg (67.99 KiB) Viewed 3901 times
