Area 51% wrote:
Do you trust where your CHT probes are? I only have two located at the rear cylinders. I installed the probes under the spark plugs and was running high temperatures (400 plus) in climb during the first 25hrs as expected. No relief came at 30hrs, so I relocated a probe to the recommended spot about an inch away from the plug. Abbra-Kadabra....that probe has never topped 400deg no matter how hard I try. The other (still under the plug) sits on 420+ during a prolonged climb while the other is cooling it's heels at 375. Across the board, I get a 50deg difference between the two.
Area 51% wrote:You could run a "blast tube" to force outside air onto the #3 CHT probe to cool it, like others have done to bring their oil temperature down.
OR..........
If the damn probes weren't $65 each, I'd relocate the other one.
daleandee wrote:
Many moons ago Charlie Radford, myself, and a couple of others were members of the "Hot Headed Club" and Charlie had done some testing very much like you have done and came to the same conclusion.
