Area 51% wrote:
Do you trust where your CHT probes are? I only have two located at the rear cylinders. I installed the probes under the spark plugs and was running high temperatures (400 plus) in climb during the first 25hrs as expected. No relief came at 30hrs, so I relocated a probe to the recommended spot about an inch away from the plug. Abbra-Kadabra....that probe has never topped 400deg no matter how hard I try. The other (still under the plug) sits on 420+ during a prolonged climb while the other is cooling it's heels at 375. Across the board, I get a 50deg difference between the two.
Area 51% wrote:You could run a "blast tube" to force outside air onto the #3 CHT probe to cool it, like others have done to bring their oil temperature down.
OR..........
If the damn probes weren't $65 each, I'd relocate the other one.
daleandee wrote:
Many moons ago Charlie Radford, myself, and a couple of others were members of the "Hot Headed Club" and Charlie had done some testing very much like you have done and came to the same conclusion.
Users browsing this forum: Google Adsense [Bot] and 99 guests
