Andy Walker wrote:Someone on the Yahoo Groups asked about batteries, so I did a search on lightweight batteries and found that Lithium-Ion batteries are starting to become available that have the same capacity as conventional batts but weigh less than half as much! For example:
http://www.shoraipower.com/p-210-lfx36l3-bs12.aspx
540 Cold Crank Amps, and 36Ah reserve capacity...for under five pounds!! Expensive, yes ($350), but you are shaving 5-8lb off your overall and FWF weights for that money, which is not insignificant.
radfordc wrote:Here's a thought. You can buy this battery for $110 http://shoraipower.com/lfx18l2-bs06-p98
Buy two of them and put them in parallel. You still have 36 amp/hr and 540CCA at a total weight of less than 3 lbs and save a $100.
radfordc wrote:I'm glad I don't have a lightweight battery. I left my master switch on this week and ran the PC625 down to under 9 v. I recharged the battery and took it to the auto parts store for a check out. It tested out better than spec!
Andy Walker wrote:radfordc wrote:The Shorai battery shown in the first post is a "lithium-IRON" battery...not a lithium-ION battery.
I'm noticed that too...I'm assuming it's an Asian company and that is a typo.
EDIT: whoops, from post above I am dead wrong.
chrisyk wrote:
A lithium iron battery is a type of lithium ion battery.
radfordc wrote:Technically they are very different: http://www.brighthubengineering.com/pow ... n-battery/
Users browsing this forum: Google [Bot] and 3 guests
