Lightweight Battery
Re: Lightweight Battery
Postby radfordc » Tue Mar 18, 2014 2:07 pm
Andy Walker wrote:Someone on the Yahoo Groups asked about batteries, so I did a search on lightweight batteries and found that Lithium-Ion batteries are starting to become available that have the same capacity as conventional batts but weigh less than half as much! For example:
http://www.shoraipower.com/p-210-lfx36l3-bs12.aspx
540 Cold Crank Amps, and 36Ah reserve capacity...for under five pounds!! Expensive, yes ($350), but you are shaving 5-8lb off your overall and FWF weights for that money, which is not insignificant.
Here's a thought. You can buy this battery for $110 http://shoraipower.com/lfx18l2-bs06-p98
Buy two of them and put them in parallel. You still have 36 amp/hr and 540CCA at a total weight of less than 3 lbs and save a $100.
radfordc
Postby vigilant104 » Tue Mar 18, 2014 2:49 pm
radfordc wrote:Here's a thought. You can buy this battery for $110 http://shoraipower.com/lfx18l2-bs06-p98
I don't think that would work out. They are 6V, so they'd have to be wired in series to make 12V, right? The CCA and amp/hour ratings would stay the same as one of these 6V batteries, (270 CCA, 9AH: same number of amps but twice as many volts=twice as much actual wattage as a single battery). If I've got that right, then using two of these 6V batteries in series would save $100, but the CCA would be 1/2 of the battery in the OP, and the total capacity would be just 1/4 of the 36 AH of that battery.
Mark Waldron
Aerovee, Trigear
vigilant104
Postby radfordc » Tue Mar 18, 2014 10:08 pm
Oops...missed the voltage part. Too good to be true.
radfordc
Postby radfordc » Sat Mar 22, 2014 10:09 am
What about this battery: http://www.batteryspace.com/LiFePO4-Pri ... t-PCM.aspx
12.8v; 20aH; 6.6 lbs; $124.00
Same price as an Odyssey PC625 at half the weight.
radfordc
Postby radfordc » Sat Mar 22, 2014 11:30 pm
I'm glad I don't have a lightweight battery. I left my master switch on this week and ran the PC625 down to under 9 v. I recharged the battery and took it to the auto parts store for a check out. It tested out better than spec!
radfordc
Postby fastj22 » Sun Mar 23, 2014 9:29 am
radfordc wrote:I'm glad I don't have a lightweight battery. I left my master switch on this week and ran the PC625 down to under 9 v. I recharged the battery and took it to the auto parts store for a check out. It tested out better than spec!
You would have been welcomed with open arms into the Flying Paperweight Club.
Postby chrisyk » Tue Mar 25, 2014 12:29 am
Andy Walker wrote:
radfordc wrote:The Shorai battery shown in the first post is a "lithium-IRON" battery...not a lithium-ION battery.
I'm noticed that too...I'm assuming it's an Asian company and that is a typo.
EDIT: whoops, from post above I am dead wrong.
A lithium iron battery is a type of lithium ion battery.
chrisyk
Postby radfordc » Tue Mar 25, 2014 10:15 am
Technically they are very different: http://www.brighthubengineering.com/pow ... n-battery/
No one ever refers to a Lithium Iron battery as a "Lithium Ion".
radfordc
Postby vigilant104 » Tue Mar 25, 2014 10:58 am
radfordc wrote:Technically they are very different: http://www.brighthubengineering.com/pow ... n-battery/
Thanks for the link. For our use, the Li-Iron sounds pretty good (safety, longevity, cost). And, even though the weight of a Li-iron battery might be more than Li-ion, it should still be less than 1/2 of lead acid.
Specific energy (watt hours/kg)
Lead acid: 41
Li-iron: 90-110
Li-ion: 100-250
In theory, it sounds good to lose 6 lbs of battery weight, but right now that big chunk of lead up on the firewall is helping my CG situation when I'm fully loaded.
Mark Waldron
Aerovee, Trigear
vigilant104
Postby chrisyk » Mon Apr 14, 2014 11:58 am
You are correct. A lithium iron battery is very different from a lithium ion battery. I'll rephrase my comment. A lithium iron battery is in the lithium ion battery family. A lithium ion battery is rechargeable as opposed to a lithium battery which is not rechargeable. Some types of lithium ion batteries are:
Lithium ion manganese oxide battery (IMR)
Lithium ion polymer battery
Lithium iron phosphate battery
Lithium–sulfur battery
Lithium–titanate battery
Here's a quote from wikipedia.
"The lithium iron phosphate (LiFePO4) battery, also called LFP battery (with "LFP" standing for "lithium ferrophosphate"), is a type of rechargeable battery, SPECIFICALLY A LITHIUM ION BATTERY, which uses LiFePO4 as a cathode material."
This is on the internet so it must be true.
chrisyk
Return to Electrical System
