Assembly manual
Assembly manual
Postby Sonex1517 » Wed Sep 10, 2014 10:15 pm
We have some of the files I saved on the foundation website and are always looking for more! The spreadsheet is one of them
http://sonexfoundation.com/Files.html. <<------Click here
http://sonexfoundation.com/uploads/sheet_plan_grid_update6.pdf <<-----Or click here
Chicagoland
Currently butchering the wing rigging on a semi-regular basis
N1517S reserved
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Re: Assembly manual
Postby LLR » Sat Sep 13, 2014 6:29 am
Tony, Frank and Robbie: I can't thank you guys enough for the assistance. I've been told this forum is an excellent resource for anyone even contemplating a Sonex build; now I know that advice is indeed correct. It's frustrating to be all stoked about a major project, only to get hung on some minor glitch (as I am an engineer, you'd think I'd be used to this). But it's just as gratifying to know there's a large group of folks who've experienced the same frustrations, and are willing to share their knowledge for the good of all.
Thanks again!
~Larry
~Larry
N167JK
LLR
Re: Assembly manual
Postby Darick » Tue Sep 23, 2014 9:38 pm
While not an assembly manual question, this is an assembly order question. The Sonex instruction sheet on skinning the wing says to attach the top skin, flip over, then the bottom skin, flip over again and attach the top leading edge, flip over again pull the leading edge down and fasten it.
I've got the top skin drilled and the bottom skin drilled, and wondering if there is a good reason to start with the top leading edge which means I have it flip it again. Id rather just leave the wing in its present position, that is bottom side up, and put the bottom leading edge on first. I'm having a difficult time flipping the wing especially as it getting heavier all the time. Is there a good reason not to do this?
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Assembly manual
Postby daleandee » Tue Sep 23, 2014 10:52 pm
Hi Darick,
The best answer I ever got to a question like yours came from my building mentor Richard "Dick" Fisher who would always ask me ...
"What do the plans say?"
Dale
N319WF
daleandee
Re: Assembly manual
Postby ScottM-Sonex1629 » Tue Sep 23, 2014 11:10 pm
Darrick,
I built both of my wings just like you are describing. Started at the top, then did the bottom, once I was ready to rivet the skin on the bottom was looking at me, and I just went for it. Probably forget to read the plans order of build for that step. I had no issues.
Just remember to square and level you wing before you begin to rivet.
Be extra careful with the leading edge skins. More than one of us had creased the aluminum skin trying to handle it and stretch it back to the spar.
Good luck!
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Re: Assembly manual
Postby Rynoth » Wed Sep 24, 2014 11:20 am
Here is a link to the sonex instruction sheet for wing skinning: http://www.sonexaircraft.com/documents/ ... W07-02.pdf
Users browsing this forum: Google [Bot] and 75 guests
