falvarez wrote:I added a washer between the hydraulic brake unit and the wheel hub to provide the extra space needed; otherwise, the pads were pressed against the disk even when fully retracted. I used a unibit to drill out hole in the washer, so you only need to find one with the correct outer diameter.
mike.smith wrote:BTW, after 50 hours flying my Sonex I'll offer my opinion about differential braking (I have a tail dragger). Like most people I have spent over 400 hours flying planes with differential brakes, so I got used to them. But I have not found any need for them on a Sonex. It would be nice to have the brakes on the control stick like some people have done, but I've gotten used to the single handle near the flaps.
mike.smith wrote:I'm converting to the Sonex hydraulic brakes, from the machined drums. For anyone who has installed these brakes, did you do anything about the wimpy tab on the bottom of the axle assembly? It bends as easily as a piece of cardboard, and has been incapable of not doing so with my standard brakes, leading to brake assemblies that grab the drums because they won't stay square to the drums.
N439M
