by MichaelFarley56 » Fri Sep 05, 2014 6:44 pm
Hi George,
I've flown with several other guys in the 180-200 lb range and 8-10 gallons of fuel. I'm over the 1100 lb. max takeoff weight recommended by Sonex, but as long as the temps aren't real high my plane still does fine. Remember that I'm based out of an airport in Ohio where the field elevation is only around 1000'.
If at all possible, I try to keep my takeoff weight at or below 1100 lbs and as a result, I have no problems taking my wife a ride!
Waiex #0056 - N569KM (sold)
Onex #245
