by ltaylor » Sat Aug 16, 2014 10:23 am
I neglected to record my deck height or compression ratio and work has pulled me from my build for over a year. Can someone advise on how to determine the ratio 8:1 or 7:1 without removing the heads/jugs? I'm thinking that using compression or measuring from the piston at TDC to the outside of the spark plug hole would work. I'd appreciate any advice and numbers if either of these two techniques would work. I'm sure that I set up for 8:1, but I need to be "sure!"
Lane
Sonex Waiex #150--90% complete
KOSC
