Manual parking brake
Postby kmwoody » Mon Aug 11, 2014 3:34 pm
Just installed a parking brake in mySonex for the stock drum brakes. Saw Jeremy using it in the Turbo video. Took a picture of it when I was at Airventure. Cost me a little more than I wanted to spend --.58 cents. What a great idea. I can now get rid of my orange strap with a slip knot that barely held the brakes at idle. This holds me through my run-up easily. Gotta love experimental aircraft.
Ken W
Sonex 959 250 hrs
Aerovee 464 50 hrs since overhaul
kmwoody
Re: Manual parking brake
Postby falvarez » Mon Aug 11, 2014 3:41 pm
I noticed that comment in the video as well. Can you post the photo that you took of it?
Frank Alvarez
Sonex #800, Aerovee 2.1
falvarez
Postby kmwoody » Mon Aug 11, 2014 7:47 pm
Frank as soon as I figure out how to post an image I will.
Ken W
kmwoody
Postby tonyr » Mon Aug 11, 2014 8:49 pm
So.. is it just a clip or angle piece attached to the flap lever?
I've been thinking about something similar
You could email me the pic and I'll post it? (Promise) aj_richo at yahoo.com.au
Sonex #813
First Flight... 4 Oct 14
298 hours having fun!
tonyr
Postby tonyr » Tue Aug 12, 2014 7:40 pm
Ken kindly forwarded some pics of the park brake detail, as fitted to the factory Turbo and Ken's installation.
Super simple and easy to implement!
As the photos would take up a lot of room in your browser, I have organised them into a web page here http://sonexaus.wikispaces.com/SImple+Park+Brake
( Ok I shamelessly added them to a Tips and Tricks area of the Aussie builders website, sonexaus.wikispaces.com)
enjoy!
Sonex #813
tonyr
Postby Bryan Cotton » Tue Aug 12, 2014 8:52 pm
Clever!
Postby avee8r » Wed Aug 13, 2014 8:16 am
Maybe someone has already posted this but to save the weight, complexity, and hindrance of the screw and spacer etc... I simply move the flaps out of the fully retracted position, then pull the parking brake handle back and put it into the "0 degree" flap slot. Works like a charm, no added weight or complexity, and will hold the plane to 2300 rpm if the cable is adjusted properly.
Happy Landings
John
N50NX
avee8r
Postby daleandee » Wed Aug 13, 2014 4:21 pm
avee8r wrote:to save the weight, complexity, and hindrance of the screw and spacer etc... I simply move the flaps out of the fully retracted position, then pull the parking brake handle back and put it into the "0 degree" flap slot.
John
N50NX
That's very similar to the way Tony Spicer did his except his went into the 10º flap slot. The advantage, besides all the positives you've already mentioned, is that you can fully lower the flaps for exiting while the parking brake is still engaged.
I have the Tracy O'Brien hydraulics and use the stick mounted lever/master cylinder. I presently use a piece of velcro to hold the handle for a temporary parking brake but if anyone else has a better idea ... I'm all ears.
Dale
N319WF
Postby tonyr » Wed Aug 13, 2014 6:50 pm
I think the flap slot idea is ok if you have arms long enough to reach the brake handle in its relaxed fully forward position.. whilst strapped in
having shorter arms might have led to a different solution.. ?
Just saying.. :lol:
Sonex #813
tonyr
Postby rizzz » Wed Aug 13, 2014 7:38 pm
avee8r wrote:Maybe someone has already posted this but to save the weight, complexity, and hindrance of the screw and spacer etc... I simply move the flaps out of the fully retracted position, then pull the parking brake handle back and put it into the "0 degree" flap slot. Works like a charm, no added weight or complexity, and will hold the plane to 2300 rpm if the cable is adjusted properly.
Happy Landings
John
N50NX
That's how I've got mine set up:
Users browsing this forum: No registered users and 64 guests
