Mechanical tach, oil temp and oil pressure for AeroVee
Postby Sonex1517 » Sat Jun 07, 2014 5:53 pm
Hi Everyone
Our AeroVee arrived this week (well, most of it. Two backordered head assemblies). So our focus now is on assembling it.
Some questions for this who have actually used mechanical gauges with an AeroVee.
I am interested in specific part numbers for a mechanical tach (if one is compatible with an AeroVee), old fashioned mechanical oil pressure and oil temperature.
Thank you.
Chicagoland
N1517S reserved
Re: Mechanical tach, oil temp and oil pressure for AeroVee
Postby MichaelFarley56 » Sat Jun 07, 2014 11:31 pm
All I can tell you Robbie is that i used a basic 0-100 psi mechanical oil pressure gauge from AutoZone. You have a couple of basic options but they're all about the same. Everything else I have via my MGL EFIS.
Congrats on the engine delivery!
Postby wlarson861 » Sun Jun 08, 2014 1:23 am
I bought a mechanical oil pressure as a cross check to my Enigma. Less than $20 at O'Reily auto parts. The picture shows it in the right corner under the panel.
http://sonexbuildersandpilotsfoundation ... /h20361158
Bill Larson
N861SX
wlarson861
Postby Bryan Cotton » Sun Jun 08, 2014 7:30 am
When I was a kid we would go to JC Whitney for gauges in Bugs and the American iron.
Bumped up - analog tach, oil temp and oil pressure for AeroV
Postby Sonex1517 » Thu Aug 07, 2014 3:44 pm
Bumping this post again.
I am very interested in hearing from anyone who has installed analog oil temperature, RPM, and/or oil pressure (electrical, not tubed) gauges with an AeroVee.
Appreciate the replies I got earlier.
Robbie
Re: Bumped up - analog tach, oil temp and oil pressure for A
Postby fastj22 » Thu Aug 07, 2014 9:16 pm
Sonex1517 wrote:Bumping this post again.
Robbie
I installed all electric analog VDO gauges on my Karmann Ghia. Oil temp, pressure, tach, and fuel. Looked cool too.
http://www2.cip1.com
Postby n502pd » Fri Aug 08, 2014 1:04 pm
Hi Robbie, I have analogue instruments on my Sonex, but am still building. Pannel is finished but not installed. I do have electronic tach (it was really cheap, and worked) I have the capillary tube oil temp and the mechanical pressure gauge too. call me if you need, or email me! 903-818-0496 :)
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Postby kmwoody » Fri Aug 08, 2014 5:45 pm
Robbie, definitely go with a mechanical oil pressure gauge. I had fluctuating electrical readings on my MGL, changed the sender twice, and finally installed a mechanical gauge. Electronic reads 65 in cruise, spiking to over 100. Mechanical steady at 42 to 45.
kmwoody
Postby Sonex1517 » Fri Aug 08, 2014 6:29 pm
As clarification - when you say mechanical are you talking about an oil pressure line to the gauge in the cabin?
Chicagoland
N1517S reserved
Postby kmwoody » Sat Aug 09, 2014 6:01 pm
Robbie, yes, tube to gauge. There is another builder having high electronic pressure on his Stratomaster. (I have an Enigma) He hooked up a test gauge, mechanical, and his is reading 42 @ 3000 rpm. For $20 its a no brainer.
Ken W
kmwoody
Users browsing this forum: No registered users and 89 guests
