SvingenB wrote:I wonder why that is? The turbo engine is producing more HP, and this leads to more heat, normally. When the CHT decreases this can be caused by more/better cooling, more retarded ignition or richer mixture, and of course any combination. Still, this is a strange thing to do when the engine is producing more HP. hmmm?
This is just my guess so please take it as my two cents only, but if I were to guess, I'd say it's a combination of several different factors.
First, remember that by design, the AeroInjector is already inside the cowling so by stock design, the engine is already breathing "warm" air. I absolutely agree that forced induction will raise the intake air temperature, but it may not be as huge as a temperature difference as we all think. Plus, with the "pull through" turbo setup the fuel is probably already atomizing at the turbo which may help keep things cool as the air enters the intake system.
Second, I believe turbo users will be running their engines richer than "normal". Remember, the current estimate is that we will be running close to 8 gallons per hour at full throttle with the turbo so I assume we will be swapping from the #2 needle to either a #2.5 or #3 in order to richen the mixture. Just like Jeremy said at the Oshkosh Open House, more air needs more fuel!
Third, I wonder if the RPMs will drop a little. With a higher pitch prop we may be able to get away with slightly reduced RPMs on takeoff and cruise. Right now my AeroVee is spinning around 3175 RPM at a full throttle climb and I run around 3200 in cruise. If I can spin my engine at only 3000 RPM in climb and lower RPMs in cruise, that may help temps.
Finally, with 25 miles per hour more air going into the cowling, obviously that will help cool things down as well. A good test was a test flight I did yesterday; at 5500' and 3200 RPM my hottest cylinder stabilized around 330-340 degrees. In order to perform some high airspeed tests, I left the throttle alone but pushed the nose over until I registered around 160 mph indicated. Same power but more airflow gave me much cooler CHT readings. They stabilized around 290-300 during the descent. Obviously this is a slightly skewed test, but there's some valid math behind it.
Regardless, I'm really excited that the turbo engine is staying cool. I gather that was a big concern but it's always nice to hear when it works out!
