Wheel pant screws
Wheel pant screws
Postby mike.smith » Sun Aug 03, 2014 3:44 pm
I'm having a hard time keeping all the wheel pant screws from loosening up. Even with Loctite some of them seem to loosen up pretty quickly. And adding Loctite every time is a pain. Does anyone have any solutions?
Re: Wheel pant screws
Postby fastj22 » Sun Aug 03, 2014 6:22 pm
I had the same issue. Lost one pant in flight because of it.
I upsized to ¼ bolts with nylon nut plates. So far so good.
http://youtu.be/R5wykdE6R94
Postby mike.smith » Sun Aug 03, 2014 7:02 pm
fastj22 wrote:I had the same issue. Lost one pant in flight because of it.
Wow! Quite the video!
Mike
Postby DCASonex » Mon Aug 04, 2014 9:47 am
Drilled head bolts, wire tied.
Common aluminum (not SS) pull rivets with mandrels knocked out make nice neat holes in fiberglass to route wire through.
DCASonex
Postby fastj22 » Mon Aug 04, 2014 7:39 pm
DCASonex wrote:Drilled head bolts, wire tied.
That's a good idea. Do you have any pictures so we can visualize it?
Postby andrewp » Tue Aug 05, 2014 9:14 am
I just want to say that the video was absolutely amazing. Nice job on the landing.
Similar to the other posters, 3/16 screws, nut plates and in my case a sort of star fitting to allow the screws to be further away from the center of the axle. Had a little trouble with the bolts holding on the fitting (they are shared with the brakes), but wheel pants have been rock solid.
AP
#618
andrewp
Return to Sonex
Users browsing this forum: No registered users and 61 guests
